Run two Bass Shakers with seperate outputs?  Topic is solved solved with post #18975
Postby KristofferHof » Thu 10. Mar 2016, 15:29
Hey all!
I was wondering if it is possible to run two or more Bass Shakers with seperate outputs with the X-Sim Converter? E.g. one Bass Shaker for engine RPM and one for bumps.
Thanks,
Kristoffer
KristofferHof
Re: Run two Bass Shakers with seperate outputs?  Topic is solved
Postby sirnoname » Thu 10. Mar 2016, 20:25
Yes, there is a extreme old and not tested bass shaker plugin for 8 channel cards. The idea was to make 4 shakers and per car a profile for front or back motor.
You can also use midi shaker and bass shaker. As far I know you might also copy the shaker dll file in the plugin folder.
Postby KristofferHof » Thu 10. Mar 2016, 23:05
Thank you very much for your answer! Copying the Bass Shaker dll worked perfectly.
KristofferHof
