converter freeze with windows 10 pro  Topic is solved solved with post #18114
Postby lufykun » Thu 19. Nov 2015, 10:26
hello i upgrade my pc to windows 10 and have a big probleme with converter it freeze when try launch any profile
extractor work fine no problem :mrgreen: :mrgreen:
on my converter i see my ip adress ,i disable my bluetooth adpter, disable firewall and my kaspersky
try to move folder Interface plugins but same thing freeze :evil: :evil: :evil:
when i try to launch any profile it's just freeze no pop up i can't close it (need to use task manager for that )
thank you for your help
lufykun
Re: converter freeze with windows 10 pro
Postby sirnoname » Sat 21. Nov 2015, 10:56
Make some screenshots of program setup, interface setup and your setup panel of used hardware.
Did already tried to use the x-sim registry cleaner with the converter button?
Postby lufykun » Sat 21. Nov 2015, 21:30
hello
to explain better my problem
i use x- sim with Digital dashboard with TM1638 and Arduino Nano v3 (for now )
i uninstall x-sim ,reboot pc, install x-im with clean registery (same problem)
when i said i can't close converter i launch converter(without launch any profile ) when try close it he stop working
i hope it's the good screen you ask me if not please give me a screen for do the same thing on my computer
thank you
lufykun
Postby sirnoname » Sun 22. Nov 2015, 13:30
First question would be, why you open the converter if you do not need it? The data export is normally done in the extractor which send data to your gauge.
Now try to uncheck all the plugins in the interface setup and find out which one will freeze.
Postby lufykun » Sun 22. Nov 2015, 15:02
hi
because i just not finish to build my motor station (in few week)
i use converter because my dasboard is recognized like axis
i have unchecked all plugin but still freeze when try close or open a profile
lufykun
Postby sirnoname » Sun 22. Nov 2015, 15:19
Very strange.
Upload such a profile here.
Postby lufykun » Sun 22. Nov 2015, 15:42
hi
for me the strange it's when i try just close it without do anything it's freeze
here my profile (for lotus 79 in iracing)
[Overall]
includesaxisdata=1
includesaxissynaptrix=1
includesaxisuso=1
includesgauges=1
includesusoconfig=1
includesprogramconfig=1
profileversion=2
numberofaxis=3
[Calibration]
numberofsequences=0
calibrationtype=0
[Axis0]
Axisname=RPM
isasymetricoffset=1
calibrationoffset=-2147483648
numberofmath=1
Math0PluginID=1
Math0sliderused=0
Math0SettingValue0=57
Math0SettingValue1=0
Math0SettingValue2=0
Math0SettingValue3=0
Math0SettingValue4=0
Math0SettingValue5=0
Math0SettingValue6=65535
Math0SettingValue7=65535
Math0SettingValue8=0
Math0SettingValue9=0
Math0SettingValue10=100
Math0SettingValue11=0
Math0SettingValue12=2
Math0SettingValue13=0
Math0SettingValue14=0
Math0SettingValue15=0
Math0SettingValue16=0
Math0SettingValue17=0
Math0SettingValue18=0
Math0SettingValue19=0
Math0SettingValue20=0
Math0SettingValue21=0
Math0SettingValue22=0
Math0SettingValue23=0
Math0SettingValue24=0
Math0SettingValue25=0
Math0SettingValue26=0
Math0SettingValue27=0
Math0SettingValue28=0
Math0SettingValue29=0
Math0SettingValue30=0
Math0SettingValue31=0
USODivider=1
USOMultiplier=1
USOAdd=0
USOBandwidth=1
USOValuetype=0
[Axis0Synaptrix]
synaptrixnote=
numberofspeeds=1
threadpriority=0
directoutputport=none
referenceinputport=none
refmin=0
refmax=4294967295
invert=0
sensibiltiy=0
globalminimumpwm=0
moveandstop=1
inertia=0
numberofstopports=0
speed0name=single speed or dynamic output
speed0enablevalue=1
speed0numberofpositivepulses=0
speed0numberofnegativepulses=0
[Axis1]
Axisname=Speed
isasymetricoffset=1
numberofmath=1
Math0PluginID=1
Math0sliderused=0
Math0SettingValue0=56
Math0SettingValue6=65154
Math0SettingValue7=65154
USODivider=1
USOMultiplier=1
USOAdd=0
USOBandwidth=1
USOValuetype=0
[Axis1Synaptrix]
synaptrixnote=
numberofspeeds=1
threadpriority=0
refmin=0
refmax=4294967295
invert=0
sensibiltiy=0
globalminimumpwm=0
moveandstop=1
inertia=0
numberofstopports=0
speed0enablevalue=1
[Axis2]
Axisname=Gear
isasymetricoffset=1
calibrationoffset=0
numberofmath=1
Math0PluginID=1
Math0sliderused=0
Math0SettingValue0=60
Math0SettingValue6=128
Math0SettingValue7=128
USODivider=1
USOMultiplier=1
USOAdd=0
USOBandwidth=0
USOValuetype=0
[Axis2Synaptrix]
synaptrixnote=
numberofspeeds=1
threadpriority=0
refmin=0
refmax=4294967295
invert=0
sensibiltiy=0
globalminimumpwm=0
moveandstop=1
inertia=0
numberofstopports=0
speed0enablevalue=1
[ProgramSettings]
SynaptrixTaskPriority=2
MathTaskPriority=2
MainTaskPriority=2
MathPause=10
SynaptrixPause=20
holdposition=0
centerdelay=-1
usemathcenter=0
autohwscan=0
unify=0
max_unify=10000
autoisolate=0
showmathsliders=0
[Autostarttrigger]
autostarteffectnumber=0
autostartenabel=0
autostarttriggeronplaying=0
autostarttriggeroncreated=0
autostarttriggeronplugin=0
[GaugeSlotAxis]
visualaxis1=1
visualaxis2=2
visualaxis3=3
visualaxis4=4
visualaxis5=5
visualaxis6=6
[SliderSettings]
numberofsliders=0
[Gauges]
minimizeall=0
minimizestartup=0
gaugename0=
gaugeconfigfile0=
gaugetype0=-1
gaugename1=
gaugeconfigfile1=
gaugetype1=-1
gaugename2=
gaugeconfigfile2=
gaugetype2=-1
gaugename3=
gaugeconfigfile3=
gaugetype3=-1
gaugename4=
gaugeconfigfile4=
gaugetype4=-1
gaugename5=
gaugeconfigfile5=
gaugetype5=-1
gaugename6=
gaugeconfigfile6=
gaugetype6=-1
gaugename7=
gaugeconfigfile7=
gaugetype7=-1
gaugename8=
gaugeconfigfile8=
gaugetype8=-1
gaugename9=
gaugeconfigfile9=
gaugetype9=-1
gaugename10=
gaugeconfigfile10=
gaugetype10=-1
gaugename11=
gaugeconfigfile11=
gaugetype11=-1
gaugename12=
gaugeconfigfile12=
gaugetype12=-1
gaugename13=
gaugeconfigfile13=
gaugetype13=-1
gaugename14=
gaugeconfigfile14=
gaugetype14=-1
gaugename15=
gaugeconfigfile15=
gaugetype15=-1
gaugename16=
gaugeconfigfile16=
gaugetype16=-1
gaugename17=
gaugeconfigfile17=
gaugetype17=-1
gaugename18=
gaugeconfigfile18=
gaugetype18=-1
gaugename19=
gaugeconfigfile19=
gaugetype19=-1
gaugename20=
gaugeconfigfile20=
gaugetype20=-1
gaugename21=
gaugeconfigfile21=
gaugetype21=-1
gaugename22=
gaugeconfigfile22=
gaugetype22=-1
gaugename23=
gaugeconfigfile23=
gaugetype23=-1
gaugename24=
gaugeconfigfile24=
gaugetype24=-1
gaugename25=
gaugeconfigfile25=
gaugetype25=-1
gaugename26=
gaugeconfigfile26=
gaugetype26=-1
gaugename27=
gaugeconfigfile27=
gaugetype27=-1
gaugename28=
gaugeconfigfile28=
gaugetype28=-1
gaugename29=
gaugeconfigfile29=
gaugetype29=-1
gaugename30=
gaugeconfigfile30=
gaugetype30=-1
gaugename31=
gaugeconfigfile31=
gaugetype31=-1
gaugename32=
gaugeconfigfile32=
gaugetype32=-1
gaugename33=
gaugeconfigfile33=
gaugetype33=-1
gaugename34=
gaugeconfigfile34=
gaugetype34=-1
gaugename35=
gaugeconfigfile35=
gaugetype35=-1
gaugename36=
gaugeconfigfile36=
gaugetype36=-1
gaugename37=
gaugeconfigfile37=
gaugetype37=-1
gaugename38=
gaugeconfigfile38=
gaugetype38=-1
gaugename39=
gaugeconfigfile39=
gaugetype39=-1
[USOConfig]
numberofcoms=1
startupfix=0
comname0=COM2
ipaddress0=127.0.0.1
combits0=1
comparity0=0
comstopbits0=0
comspeed0=125000
comstartparser0=
comcycleparser0=R~a01~~110~S~a02~G~a03~
comstopparser0=
comwaitafterinit0=0
comwaitaftercycle0=1
comwaitafterstop0=0
lufykun
Postby lufykun » Sun 22. Nov 2015, 15:52
when i says close it's about the converter.exe without launch any profile and unchecked all plugin interface
lufykun
Postby sirnoname » Sun 22. Nov 2015, 16:52
Do you know how to export a registry value?
Would be fine if you export the X-Sim registry entry in HKLM / software / X-Sim (on 64 bit OS in the syswow64 section) and upload it here. As Zip this time.
Re: converter freeze with windows 10 pro  Topic is solved
Postby lucasdiulbern » Sun 22. Nov 2015, 19:03
I was having the same problem, managed to resolve by doing a clean installation of Windows 10.
lucasdiulbern
Images: 20
