Slider - How to use?
Postby Bruceaust » Mon 16. Jul 2012, 15:10
I have been playing around with "Xsim3 converter" for a while now and I can't seem to get the sliders to change any values. I have assigned the slider by right clicking the math line, but the output value does not change when I move the slider. I must be doing something wrong.
Any help please.
Bruceaust
Re: Slider - How to use?
Postby sirnoname » Mon 16. Jul 2012, 15:14
make a screenshot, the selected lines should get yellow
Postby Bruceaust » Mon 16. Jul 2012, 15:31
Thank Sir,
here is the screen shot
Bruceaust
Postby tronicgr » Mon 16. Jul 2012, 19:12
Did you press the "TRY SEND DATA" on the extractor?
Even its just a test plugin it needs a way to sent the data!!
Postby sirnoname » Mon 16. Jul 2012, 20:41
I think you missunderstand a slider ;)
It will decrease in percent your selected result value.
It will not start a new value. Use the test plugin in the extractor to generate a value with the slider tablet.
Postby Bruceaust » Tue 17. Jul 2012, 01:55
Thankyou Sirnoname,
You are correct! :D I did not understand how the slider works.
Following your suggestion, I found the Test Tablet.exe in the plugin folder. This is exactly what I am looking for to test my hardware/motion etc.
I will now be able to safely test the movement on my sim before I connect it to any game/sim application.
Thanks again
Bruceaust
