Thanos 6DOF math plugin  Topic is solved solved with post #17649
Postby Zoszko » Sat 3. Oct 2015, 01:08
I am working on my opensource controler for peumatic simulators with 6DOF. I am tryin gto use the Thanos 6DOF math plogin in order to send the position of each cylinder, but there is no data on the analyzer or on my device. I have made the 6 axis and I am feeding that in to my board with USO. I have also changed the .ini file to
Code: Select all
[Settings]
SW_Simulation=1
Am I missing something?
Please help.
Zoszko
Zoszko
Re: Thanos 6DOF math plugin  Topic is solved
Postby Zoszko » Sun 4. Oct 2015, 11:17
:!: SOLVED! :!:
Zoszko
