Arduino can't be added to field "Select entry..."
Postby hape » Sat 8. Aug 2015, 13:05
hi @all
i'm struggeling with the following thing:
i have made a program in the Arduino so i can see the input. But unfortunately‎ i can't add the arduino to the "select entry to edit" field in the output setup/Universal Serial Output.
In the field "Enter available comport..." there is my Arduino Uno with the correct Com-Port (Arduino UNO - Device Path: \\.\COM5). If i than press "Add entry to list" nothing happens (the "Select entry to edit:" field is still without any entry).
Does anybody know whats going on?
If i start a game like Race07 i can see the input (also if i start the 3d SimforceGT i see a chair which moves in the correct manner).
so it would be nice if someone has a suggestion why i can't put the output to the comport.
thx for helping in advance
hape
hape
Re: Arduino can't be added to field "Select entry..."
Postby hape » Sat 8. Aug 2015, 15:20
hi
ok i have found that if the Arduino software is running this is the effect. OK this problem solved but i get nothing as input to the Arduino?
it would be very nice if someone can help.
so long
hape
hape
Postby hape » Sat 8. Aug 2015, 15:56
hi @all
so there must be a big mistake by me. If i take a look on the realtime Benchmark field in the vonverter there is
calculation / second: 400
math engine rounds/s: 100
USO engine outputs/s: 0
Synaptrix outputs/s: 0
So i think the converter doesn't do anything on the com5 port. But why? Is there a hidden field or a button which must be touched or anything to put in that there is an output?
Or does someone have a manual what i should put into the fields in Universal Serial Output to get a result?
thx for helping
hape
hape
Postby hape » Sat 8. Aug 2015, 16:31
hi @all
so i have made a test and typed in the Arduino serial monitor in the send field the characters "L00" which is after the hex to dec left actuator position to 208. So i would suggest the Arduino Code works but there is really no output from the x-sim converter (all done on 115200 baud).
hape
hape
Postby soraz » Sun 9. Aug 2015, 10:16
in converter have configured output setup (USO) and math setup ?
have load some similar configuration profile online in extractor ?
regards
soraz
Images: 67
Been thanked: 7 times
Postby hape » Sun 9. Aug 2015, 12:04
hi soraz
soraz wrote:in converter have configured output setup (USO) and math setup ?
here is what i have done:
in the USO field i have expiremented with every combination: L~a01~R~a02~ with 2 chars of "~" and so on and so on (as you can see now i have the string from your post inside)
here i have done nothing
soraz wrote:have load some similar configuration profile online in extractor ?
this question i didn't really understood (GamePc -> Extractor Laptop -> Converter)
the connection between works because i see data and also the "3D Simforce GT" works
so thx a lot for your help
hape
hape
Postby hape » Sun 9. Aug 2015, 12:40
hi
oh my god - i didn't have pressed the start button. Thats all. Yesterday i must be to tired to see this.
So thx for your help
hape
hape
Postby soraz » Sun 9. Aug 2015, 16:43
if you configure program settings, converter autostart and stop on game detect.
3788
regards
soraz
Images: 67
Postby hape » Sun 9. Aug 2015, 18:01
soraz wrote:if you configure program settings, converter autostart and stop on game detect.
3788
regards
hi @soraz
thats a good point. I will do this.
thx a lot
hape
hape
