X-sim output randomly stops - help please!
Postby andyrx7 » Thu 2. Jul 2015, 20:41
Hi all,
I recently set up X-sim to drive a single bass shaker (Buttkicker). I am using the 'bass shaker' output plugin and two games, Assetto Corsa and Project Cars. All seems to work great, except: After a short and seemingly random amount of time (sometimes 5mins, sometimes 30mins) the output signal to my sound card just stops. However I can see nothing visibly changing in either the extractor or converter applications. The 'start/stop' button in the converter doesn't change appearance, it still indicates the converter is on. Neither the converter nor the extractor applications crash or are unresponsive. The output just goes dead.
Clicking 'stop' in the converter and then 'start' again does not fix the problem, the output stays dead. But, whenever this happens, I can fix the problem by closing and re-opening both applications, clicking 'start game' in extractor (even with the game still running) and then 'start' in converter. Then it will work again for another little while before cutting out again.
My PC is running a 4670k i5 processor overclocked to 4.3ghz and a gtx 980 graphics card. It is well cooled and stable. I am running these games at a solid 60fps. Sound card is a MOTU ultralite. The sound card keeps outputting on its other channels so I do not think it is at fault. X-sim is outputting to one channel on the MOTU which is then feeding the Buttkicker amplifier. I am running a Fanatec wheel and pedal setup.
These drop-outs happen with both games. I notice no difference there.
I searched the forum and found someone else referencing this problem, in one of the Assetto Corsa threads. That person thought the problem was due to the 'enable auto-start trigger' box being checked and suggested deselecting this feature. However, that box has always been unchecked since I installed the X-sim software, so I don't think this is the problem in my case.
Thank you in advance for any advice!
andyrx7
Re: X-sim output randomly stops - help please!
Postby Evolaco » Wed 11. May 2016, 10:05
I have the same problem , only solved by closing Converter and running it again.
you have found a solution ?
Evolaco
Postby sirnoname » Wed 11. May 2016, 18:57
Try disable the soundcard to test the bare converter or change to midishaker, which can do the same.
Postby JBDLink » Wed 8. Jun 2016, 13:35
I have exacty the same problem, the bass shaker output stops after a random time.
I have 4 bass shakers and an Arduino in my x-sim configuration.
When the bass shakers output stops playing sound, the X-Sim don't stop working.
I have my arduino conected through OBD2 (It doesn't use the Converter) and when bass shakers stop playing sound, the Arduino is still working perfect.
I think the problem could be on the Bass Shaker plugin or in the Corverter aplication.
any idea how to solve it?
Thanks in advance!
JBDLink
