Only LFS working.
Only LFS working.
Postby Mitchelll0181 » Wed 17. Jun 2015, 21:56
Hello guys. I'm struggling with X -sim.
i don't get any data from my favorite games, : Dirt3 and Grid2
The test tool works and so does Live for speed.. i can see values coming in..
Can anybody help me where too look ?
Mitchelll0181
Re: Only LFS working.
Postby sirnoname » Thu 18. Jun 2015, 00:45
X-Sim does not use LFS data with this games, however you can manually downgrade to this with changing the hardware config file of codemaster to extradata 0. Check simple this config files. We can also dublicate the data for pass through to other software.
Postby Mitchelll0181 » Thu 18. Jun 2015, 07:55
I use the grid profile when using Grid offcourse.. but there is no data coming in.
Should work without any additional plugins right ?
The included test tool works, i can see data coming in from it. so the link between the extractor and converter is working ..
But Grid2 and Dirt3 are not..
Mitchelll0181
Postby sirnoname » Thu 18. Jun 2015, 18:29
Simple solution, delete game, delete configs in appdata. Now install game, run X-Sim Wizard and let do it for you. Maybe other programs have changed configs.
Postby ligno1 » Sat 15. Aug 2015, 20:50
Hello,
I have tried configuring Dirt3 to make it works with Xsim but it doesnt work.
I make the search with the extractor, it finds the game but when I run it converter but it doesnt detect it:
This is the configuration that I have in the game:
Could anyone please help me? I dont know what Im doing wrong.
Thank you.
ligno1
Postby sirnoname » Sat 15. Aug 2015, 20:54
If you press play game button, will the button stay grey while game is running?
Make also a screenshot of the minimized Dirt Codemaster window in the taskbar.
Postby ligno1 » Mon 17. Aug 2015, 11:05
sirnoname wrote:If you press play game button, will the button stay grey while game is running?
No, it doesnt. I have tried to open other game (GameStockCar or Rfactor) and it turns grey instead. When I start dirt 3 it turns grey only one second and then it becomes blue again.
Here you have the picture of the full desktop:
ligno1
Postby spyderwash » Mon 17. Aug 2015, 14:35
if the game is on steam, you're missing the launch parameters to put
spyderwash
Postby ligno1 » Mon 17. Aug 2015, 16:33
spyderwash wrote:if the game is on steam, you're missing the launch parameters to put
What parameters exactly? Where should I change it? Thanks.
ligno1
Postby spyderwash » Mon 17. Aug 2015, 19:01
exctractor in the game right to edit call parameter
steam: // rungameid / 44320
this code are on the icon of the game right
then use lfs profile and settings required
<motion enabled="true" ip="127.0.0.1" port="4123" delay="1" extradata="0" />
spyderwash
