error writing on serial com 2
Postby arne » Tue 14. Apr 2015, 16:54
My simulator works great if I play dirt 3 with my keyboard. But I get this error when I plug my racing wheel (logitech g27) in my computer. Can somebody helps me?
2DOF: X-sim - Arduino - Motomonster
http://www.x-sim.de/forum/viewtopic.php?t=1640
arne
Images: 31
Re: error writing on serial com 2
Postby sirnoname » Tue 14. Apr 2015, 19:03
Error on writing is a error behind the init of the comport. This comes mostly because of instable USB devices. In your case the Arduino on Com2 say there was a short disconnect. You can check this with a USB device logger or the free serial port monitor. A disconnect can be caused bacause of power is going over the USB cable. From the motor. Interferences or power. There is somewhere a totorial from yokoyoko for make good mass connection to your motors and remove some connections to ground.
viewtopic.php?t=289
Postby arne » Tue 14. Apr 2015, 20:28
But why works the simulator with the keyboard. It shouldn't work if its from the motors, or not?
arne
Images: 31
Postby sirnoname » Tue 14. Apr 2015, 20:30
Your steering wheel has also a motor ;)
Postby adrianovrm » Wed 15. Apr 2015, 01:57
Good night
Try to exchange the arduino comport and remake uso config for the new port... may be port com conflit.
adrianovrm
Postby adrianovrm » Wed 15. Apr 2015, 01:58
whats your arduino ? why king, mega , uno , duemilnove ?
tru to reinstall arduino software/driver and ftdi drivers too....
adrianovrm
Postby arne » Wed 15. Apr 2015, 16:51
I found my problem. I isolated my pedals of my steering wheel, so there isn't electrical contact with the frame. Everything works fine now :D
arne
Images: 31
