The logfile dialog (output setup)
Postby Riton » Sat 22. Nov 2014, 22:43
I would like to see the reaction of my engine based on the fact 26;
I fail to understand, I have the same two curves ...
I add axis 1 and 26 effect.
I thought to see the curve of the effect 26 and see the works of the engine and the curve following the effects, is not that?
3386
http://www.x-sim.de/manual/loggfiles.html
I would like to test the performance of my engine.
if I visualized the movement of the motor based on the effect, I could set my engine, the ramp ....
is that possible?
is it possible to add the values of the potentiometer for the motor response curve?
Riton
Images: 70
Been thanked: 16 times
