Opposite math plugin
Postby sirnoname » Thu 9. Oct 2014, 00:03
Hello,
many did ask for a solution to make a smaller effect with a bigger input.
Here is a example plugin which do this.
Copy this to X-Sim/Mathplugins directory and you will find it in the plugin list in the math setup.
Sample:
Make a new axis, add G-Force with speed. Now add the opposite plugin and you will see that maximum is minimum. This is not a invert which will mirror the input, it is splitted in the middle line of the math graph. You may test it with the slider panel to understand the function.
Regards,
SirNoname
Opposite.zip
(749.18 KiB) Downloaded 932 times
Re: Opposite math plugin
Postby TheXRacer » Thu 9. Oct 2014, 01:04
Many thanks Sirnoname !!!!!!! :)
TheXRacer
Images: 9
Has thanked: 5 times
