How to run X-Sim and TriDef 3D?
Postby koolpapy » Fri 22. Aug 2014, 18:39
Hello!
Here, I would like to run X-Sim, and TriDef 3D simultaneously to Play rFactor
Would you have a bright idea?
To summarize:
Each one launch an instance of rFactor
I've try to make a shortcut, but does'nt work
If I run TriDef3D with X-Sim, I get an error D3D
Heeeeelp!
Thank you for your ideas
koolpapy
Re: How to run X-Sim and TriDef 3D?
Postby sirnoname » Fri 22. Aug 2014, 19:00
Look the instruction video of the presentation viewer. The part of the steam launcher will also work for you ;)
http://www.x-sim.de/software.php?lang=e ... umentation
Minute 6
http://www.x-sim.de/manual/autoscan.html
Postby koolpapy » Fri 29. Aug 2014, 13:01
Ok thanks. ;)
I will take a look
koolpapy
