Converter won't start on Win 8.1
Postby postsol » Thu 2. Jan 2014, 22:09
Hey all
I have the problem that when i try to start the X-sim Converter, my PC asks for permission, thinks for a second and then stops thinking without anything popping up.
When i go to the joblist under the tab processes, i can see the program running.
I've tried to start it with compatabillity with Windows 7 but doesn't work.
Please help
Postsol
postsol
Images: 3
Re: Converter won't start on Win 8.1
Postby sirnoname » Thu 2. Jan 2014, 23:06
Try to remove the interface plugins out of the x-sim directory. You should get some message.
On my side it runs.
Postby postsol » Sat 4. Jan 2014, 15:41
Thanks mate it worked :D We got the program started
postsol
Images: 3
Postby sirnoname » Sat 4. Jan 2014, 15:45
Now insert step by step the plugins and find out which is blocking.
Postby xzek » Thu 29. May 2014, 00:01
I had the same problem and I did the steps as SIRNONAME suggested but when I start to put the plugins one by one at the original directory the converter again hanged.
After playing with some files and after disabling antivirus and firewall I figured it out that the problem was with those plugins who scan COM PORTS. So I took a look around the DEVICE MANAGER and I found that my bluetooth device had a link over the COM PORT, so I decided to disable the com port which the bluetooth was linked and I started the converter and BOOM!! PROBLEM SOLVED!
Apparently there's some devices over comports that causes the converter's plugin to hang. SOLUTION = DISABLE THEM.
Hope this can help anyone else with similar issues.
xzek
Postby sirnoname » Thu 29. May 2014, 02:04
Nice found, I know that problem of the control comport of BT. There are normally two comports for one serial BT connection, one of them is a control port and has no response if you open it with hyperterminal. Don't know why this port exist.
