Adding Vertical force, stops two other
Postby mariant » Tue 24. Dec 2013, 07:28
Someone knows why when i add vertical force, longitudinal and lateral forces stop working?, i have my simulator almost done, but this is going me crazy.
i will apreciate your help guys.
mariant
Re: Adding Vertical force, stops two other
Postby prodigy » Tue 24. Dec 2013, 10:47
When you're addding force, be sure that you check 'add result value' in force window instead of 'overwrite result value'. Change that for every force and try.
