Game Stopped Issue
Game Stopped Issue
Postby nclabs » Wed 27. Nov 2013, 12:38
Hi guys, I have an issue when I quit the game. Basically, when I quit the game the Converter just go crazy, and he show me a thousand of error "no game connection" and says something like "No game connections avaiable, please check network communication and press start". I use the autostart trigger, and it's load the profile automatically with no problems, but it goes crazy when I exit. Since now I always closed the converter BEFORE I quit the game to avoid that problem. Where I get wrong? Thx.
nclabs
Re: Game Stopped Issue
Postby prodigy » Wed 27. Nov 2013, 15:38
- Which game?
- What controller do you use? Arduino, Pololu...
- What version of X-Sim3?
Postby nclabs » Wed 27. Nov 2013, 15:52
I use rFactor and Assetto Corsa, same thing on both games.
I use the SCN interface only, no arduino, no pololu, no sabertooth.
For the version of X-Sim I need to check when I got home, 'cause I'm not sure of it.
Thank you for the reply.
nclabs
Postby sirnoname » Wed 27. Nov 2013, 21:08
Upload the .rn2 converter profile
Postby nclabs » Wed 27. Nov 2013, 21:35
I have the 3.0.0.6 version, and that is my profile for rFactor. Thanks again.
rFactor v1.255 profile2.rar
(1.28 KiB) Downloaded 792 times
nclabs
Postby sirnoname » Wed 27. Nov 2013, 21:51
this version is a little but old, isn't it?
http://www.x-sim.de/documents/Change%20history.txt
Postby nclabs » Thu 28. Nov 2013, 09:42
sirnoname wrote:this version is a little but old, isn't it?
Yes, it is, but I was sure that it was my fault. I will try on another computer with the newer version. Thanks!
nclabs
Postby nclabs » Wed 25. Dec 2013, 12:27
Sorry if I'm late, but I managed to try the new version just * I tried the 3.0.2.9 version but the same idential issue persist. What now?
nclabs
