USO Befehle für Pololu Interface
Postby Behle » Tue 3. Jul 2012, 18:28
Hallo,
ich habe mir für die ersten Gehversuche ein Pololu Servoboard von Robotikhardware bestellt und wollte mal fragen ob jemand bereits Parameter für die USO Schnittstelle erarbeitet hat. Leider habe ich keinen Beitrag zu diesem Thema gefunden bis jetzt. Danke für die Starthilfe.
Behle
Re: USO Befehle für Pololu Interface
Postby value1 » Tue 3. Jul 2012, 22:56
Hi Behle
Which "Pololu Servoboard" are you refering to? Do you have a Pololu item number? (e.g. Micro Maestro 6-Channel USB Servo Controller (Assembled) = Pololu item #: 1350)
value1
Images: 3
Has thanked: 12 times
Postby Behle » Wed 4. Jul 2012, 20:13
Behle
Postby Behle » Wed 4. Jul 2012, 20:27
Pololu item #: 207
Behle
Postby value1 » Wed 4. Jul 2012, 22:25
@Behle: Try this with your Pololu Micro Serial Servo Controller in Mini SSC II Mode in the USO section of the x-sim converter:
Set axis 01 as indicated in the picture. Axis 1 = ~a01~ value = (value/2*1)+0
With the command below you can regulate your servo:
Datapacket with axisinformations: ~255~~0~~a01~
255 = start byte (as defined by the pololu board)
0 = servo #
a01 = value of Axis 1 position (8bit resolution) as provided by the x-sim converter
Datapacket sent at simulatorstart and Datapacket sent at simulatorstop you can ignore.
value1
Images: 3
Postby Behle » Thu 5. Jul 2012, 18:06
Many thanks so far, i will try. :-)
Is there a reason to use the pololu mode?
Tim
Behle
Postby value1 » Thu 5. Jul 2012, 23:08
Nope :D
Edit: Does it work now?
value1
Images: 3
Postby Behle » Sun 8. Jul 2012, 23:24
Yes perfect! Thank you.
Behle
