New with XSIM- ILK Problem.
Postby elpadrino » Wed 6. Nov 2013, 03:36
Good night to all.
I'm looking to use the X-SIM software without success
Every time that I open the program appears a message that says
Found SCN5 Actuator, but emergency stop (ILK pin) was executed.
The actuator will ignored until ILK pin is tied to 24 V again.
I've tried to attach that ILK Pin (pin 8) directly to the power supply (24V) just to check if the system works but it not.
I Know that is better to fit a Zener Diode and a Resistor but for the moment, I just wanna see that the actuators works.
I've tried to change the Rs485-USB adapter for another with the same result. I'm using KMtronic Adapters.
Could you tell me what can be happen with it?
thank you
elpadrino
Re: New with XSIM- ILK Problem.
Postby sliversgyj » Wed 6. Nov 2013, 09:47
If you use a asian version SCN5,the ILK should not connect to 24v.it should be connect to 0v.
sliversgyj
Images: 34
Postby elpadrino » Wed 6. Nov 2013, 12:09
Yeeeesssss, you were right. Now it's working.
What kind of over power protection scheme may I use? or is it not necessary?
regards.
elpadrino
Postby sliversgyj » Wed 6. Nov 2013, 12:44
not need protection
sliversgyj
Images: 34
Postby elpadrino » Wed 6. Nov 2013, 12:56
Thank you so much for your help :)
elpadrino
