converter start button
Postby libory » Mon 23. Sep 2013, 11:59
Hi all, can anyone tell me please if there is a way of start/stop the converter with a key? the only way of doing it is with the mouse?
I am using it with one computer only so every time I need to run the simulator I need to go to desktop to press "start" and is giving me problems with the games after I go back to play.
Thanks.
libory
Re: converter start button
Postby sirnoname » Mon 23. Sep 2013, 12:18
Here is the autostart trigger:
http://www.x-sim.de/manual/settings.html
In the extractor you find trigger option in the motion driver.
Postby libory » Mon 23. Sep 2013, 12:28
I didn't know that, thanks a lot for that but I got games like DIRT 2/3 or Grid 1/2 where in menus or after a race don't stop sending data.
I haven't tried this autostart trigger but for what I read don't think is going to stop in game menus if there is still sending data. In that case what could I do... :(
libory
Postby sirnoname » Mon 23. Sep 2013, 12:34
The first thing you could do is check your statement again because at my side it stops on pause and menu.
The second option is to read what I wrote. The options in the extractor have button switching.
Then, as third option, you can use the trigger option in the converter to react on the transfered joystick input.
Postby libory » Mon 23. Sep 2013, 12:39
Thanks a lot, I will try that :)
libory
Postby kingh3 » Mon 30. Sep 2013, 22:49
libory wrote:Thanks a lot, I will try that :)
Hi every ones. I have a problemt with converter. When it start, it don't run, and with notice "uncheck not needed plugins" I don't understand. I done all thing i can but . . . Can you help me please? Thanks!
kingh3
Postby sirnoname » Tue 1. Oct 2013, 00:02
Very easy, the plugin that is shown above this message has same file name in the interface directory.
If one interface plugin hang on a computer you can delete this plugin out of this directory.
Some computers have there a problem I do not get into it.
