Converter does not start
Postby kevin123 » Tue 16. Jul 2013, 20:18
Hello to all
I have a problem with the latest version of x-sim 3.0.1.8 beta aluminum.
In practice starts once only and then the converter continues to load but will not start and gives me this error ....
What can I tried to reinstall and restart the pc but the same does not go ....
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Re: Converter does not start
Postby sirnoname » Tue 16. Jul 2013, 22:42
yes, fixed with 3019, you can delete some plugins out of the interface plugin dir or disable them ...
Too much plugins scanning too much comports ;)
Postby kevin123 » Wed 17. Jul 2013, 11:48
Fixed: It was the Kaspersky antivirus firewall that blocked the converter ... I do not understand why other versions are not blocked.
Excellent suggestion to delete the plugin interface so that you do not need will be faster loading of x-sim ;)
thank you very much
kevin
kevin123
Images: 132
