Strange problem with rfactor
Postby thecure » Fri 2. Nov 2012, 17:10
I've a problem with rfactor, for example, when I crash into the wall or the guardrail the motor's rotation drastically ralentate and then when I come back in the circuit the problem does not solve. Is there any parameter to fill in x-sim?Thank you
thecure
Been thanked: 5 times
Re: Strange problem with rfactor
Postby prodigy » Fri 2. Nov 2012, 17:32
Have you tried "Collision Effect" tutorial from MotionDave? To smooth thing up when you crash, so that the motors don't go crazy.
Postby motiondave » Sat 3. Nov 2012, 00:52
thecure wrote:I've a problem with rfactor, for example, when I crash into the wall or the guardrail the motor's rotation drastically ralentate and then when I come back in the circuit the problem does not solve. Is there any parameter to fill in x-sim?Thank you
That and can you please post a pic of your forces . There may be something there.
Postby thecure » Sat 3. Nov 2012, 13:52
in the next few days i think I'll send you the values
thecure
Return to X-Sim Q&A/FAQs
