Game not sending values.  Topic is solved solved with post #23333
Postby Redotix » Fri 8. Feb 2019, 22:09
I connected my pc with the pc that controls the sim, they communicate no problem if I use the slider test panel but when I use a game (rFactor) there are no values being sent to the converter, and also when I launch the game the converter doesn't automatically start but that also happens when I use the slider test.
Redotix
Re: Game not sending values.
Postby sirnoname » Sat 9. Feb 2019, 10:43
There is a start checkbox in the slider panel.
Did you use the game scanner for rFactor? Is it Steam?
Postby Redotix » Sat 9. Feb 2019, 12:10
I am not sure what start checkbox you mean. Can you please specify where it is?
Also my rFactor is nonsteam but the extractor found it automatically.
Redotix
Postby sirnoname » Sat 9. Feb 2019, 12:22
You do not see the start stop trigger checkbox?
Postby Redotix » Sat 9. Feb 2019, 12:36
do you mean the "enable autostart trigger in x-sim converter" checkbox in the program settings?
Redotix
Postby sirnoname » Sat 9. Feb 2019, 19:07
-> use the checkbox in the slider panel and it will start
Postby Redotix » Sun 10. Feb 2019, 03:34
Well I found it, so thats one problem sovled. It still send any values to the converter when playing games
Redotix
Re: Game not sending values.  Topic is solved
Postby sirnoname » Sun 10. Feb 2019, 19:59
The you must manually copy the rfactor plugin to the game and you have to choose the rfactor plugin in the extractor. You must enter a exe file, which is for sure running while you are in game. Else the play game button will return to blue color. It has to stay in grey color. For this you have the laucher option as described in the game wizard scripting. You can do this manually.
https://www.x-sim.de/documents/Howto-ga ... cripts.txt
Return to X-Sim Q&A/FAQs
