How do I get movement?
Postby Lanz » Tue 4. Dec 2018, 18:55
Hello, I have stopped my project a year ago. I wanted to start over.
My engines are two SCN5, my adapters are 2 USB-RS485, https: //robot-electronics.co.uk/products/communication-adapters/usb-rs485.html.
I've done all the correct wiring,
I have installed the software and followed all the steps of the tutorial I had.
The Extrator communicates perfectly with the Converter, when I launch the game from the Extractor, I have movement in all the axes of the converter,
When I start X-sim, the SCN5 focus well
The converter in, Interface Settings, recognizes the two actuators, I have renamed them and others ..
Come on, Input Setup Ok, Math Setup Ok, Interface Settings Ok.
But my problem is OUTPUT SETUP.
I do not know where to go, if I continue with USO, I have a behavior error, and because of Synaptrix I do not get anything,
a little help please
regards
Lanz
Re: How do I get movement?
Postby Lanz » Wed 5. Dec 2018, 20:03
What path should I follow?
Synaptrix or USO??
Lanz
Postby Lanz » Mon 10. Dec 2018, 10:14
Solved.
It was the ID, it was in 0, it was only changed by 1
Lanz
Return to X-Sim Q&A/FAQs
