Total noob needs help with setting up X-sim  Topic is solved solved with post #20392
Postby TripRodriguez » Thu 3. Nov 2016, 04:13
Hey guys, my 6DOF motion sim is finally built and now it's time to set up X-sim but this stuff is a bit over my head and very overwhelming. Is there a beginners guide or youtube series or something? I load the software and have no idea what to do!
I'll get pictures of my sim up very soon and a video of it moving a bit, it's not done cosmetically but it's fully built and wired! It's running on Thanos AMC1280USB and 6DOF Ext card.
TripRodriguez
Re: Total noob needs help with setting up X-sim  Topic is solved
Postby vicpopo » Thu 3. Nov 2016, 21:58
Hi Trip ,
Go to the software documentation section you will find some help.
You have also in the same time to setup the 6dof plugin in xsim.I would advice to you to use the 6dof plugin recently reworked from,heXpod.
On the motionsim forum there are full explaination how to setup it correctly !!
Postby TripRodriguez » Fri 4. Nov 2016, 09:44
Thanks Vicpopo! I'll check all that out and let you know if I need more help.
Here is a video of my motion sim, nearly complete and taking it's first baby steps of movement.
https://www.youtube.com/watch?v=JE7dCvlcduI
TripRodriguez
Return to X-Sim Q&A/FAQs
