Test the possibilities , frequency response
Postby Riton » Wed 19. Nov 2014, 22:43
I would like to test the possibilities of my AC motor.
is it possible to do something similar with XSIM?
generate frequencies?
or use ranges of effects, engine vibrations, but how?
thanks
Riton
Images: 70
Been thanked: 16 times
Re: Test the possibilities , frequency response
Postby sirnoname » Thu 20. Nov 2014, 00:44
Yes, the arduino XPID project is a high update PID controller and can control such vibrations.
You must only check the arduino forum for AC motor code and exchange this in the current code. All open source.
The need of this, compared to bassshakers, is a personal question. Many do like DC motors, other like SCN5 with vibrations.
Postby Riton » Thu 20. Nov 2014, 19:04
sirnoname, I do not understand too much,
I have the AMC128USB,
what I want to do, is generate, send effects to make these vivrations.
how to make an effect value to generate the vibrations with XSIM
I would like to "measure" or to see the performance of reaction engines.
send value effects for vibrating motor has different frequencies.
Riton
Images: 70
Postby Riton » Fri 21. Nov 2014, 22:19
I would like to set up small effects of the frames to calibrate the simulator and the different effects on motor output.
how to make sure that the simulator correctly retranscrive effects output?
the drive is set correctly, the sensor is he accurate enough, the effects settings is it correct?
there are many parameters.
frames of fixed effects, vibration ... could allow adjustment of the simulator.
I run on XSIM vibration, I rule the hard ware, until I get the engine vibration.
3 or 4 different effects setting to calibrate the hardware, motor, controller, position sensor ...
til is possible to do this with XSIM?
or put presets in the AMC?
Riton
Images: 70
Postby sirnoname » Fri 21. Nov 2014, 23:36
I do not know the AMC update rate, sorry here. As far I know it is the output speed of the USO. So maybe if you set there 33ms it is soo slow. 15ms would be fine. Compared: The Arduino X-PID do more than 3000 updates a second. Below 1ms.
The motor must be powerfull and the PID must be set very weak. Did this for a test. Best are magnetic electric actuators.
Engine vibration is very easy with x-sim. Take RPM as input and control the speed of a vibration motor (like in handies). Or bassshakers ;)
regards,
SirNoName
Postby Riton » Fri 21. Nov 2014, 23:47
ok , RPM , yes.
i test
Riton
Images: 70
Postby Riton » Sat 22. Nov 2014, 00:59
there was not a list of effects games on the forum?
57 RPM, it is not in DIRT 3 and GTR EVO
In what games I can find 57 RPM?
Riton
Images: 70
Return to X-Sim Q&A/FAQs
