Gear rumble effect 23
Postby Fahim » Wed 8. Jan 2014, 00:47
Is there any documentation to show how to use this? I am talking actuator movements.
When I change gear there it not enough sharp 'longitudinal' effect. I want more blip/shock
Is this what effect 23 is used for?
Fahim
Re: Gear rumble effect 23
Postby sirnoname » Wed 8. Jan 2014, 00:56
jep
Postby Fahim » Wed 8. Jan 2014, 00:58
Thank you.
Fahim
Postby Fahim » Wed 8. Jan 2014, 22:03
This effect worked. The effect becomes stronger as the gear is higher. So gear change 1 is weak, gear 2 change is stronger. 3 is even strong etc
Is there a way to make the effect equal throughout all the gears? Is this what linear washout or smooth washout are for?
Edit: http://www.x-sim.de/manual/math_setup.html
Found this. I think I will play about with these.
Fahim
Return to X-Sim Q&A/FAQs
