SimforceGT-Simulation not working  Topic is solved solved with post #17186
Postby almuhjool » Tue 18. Jun 2013, 18:41
Hi all
I have just installed x-sim
i have the Extractor and the Converter working very well and i have even (RnR 3D - Simulation) running very well
but when it comes to the SimforceGT.exe i have the folowing message "zugriffsverletzung bei adresse 005fb428 in Modul 'SimforceGT.exe'. Lesen von Adresse 000001E0"
i'am usingplease help 64Bit windows 7
and i'm on x-sim 3.0.1.8 and yes i have tried 3.0.1.4 and the same problem continues
thanks
almuhjool
Re: SimforceGT-Simulation not working
Postby sirnoname » Tue 18. Jun 2013, 20:20
Yes, happens on some computers.
We did not get any solution and we do not know why.
Postby almuhjool » Tue 18. Jun 2013, 21:03
Thank you for your replay
But does it work in the offline version ( the supporter one ) or not
almuhjool
Postby sirnoname » Tue 18. Jun 2013, 21:42
no, change the computer or windows ...
Postby almuhjool » Wed 19. Jun 2013, 13:51
guess i have to wait for future version
thanks
almuhjool
Postby timboo » Sun 23. Jun 2013, 16:50
Same problem here.
Hard- and Software I use:
Motherboard: ASUS P8H67 Rev. 3.0 Socket 1155
Proc: Intel i7 3770, 3.5 Ghz, 4C/8T
Memory: 4BG Corsair DDR3 1600Mhz
GC: Nvidia GTX660TI
OS: Windows 7 Professional 64-bit, SP1
timboo
Postby sirnoname » Fri 19. Jul 2013, 14:29
I have added in the current version the old beta version of this application.
It has some problems with ATI OpenGL but perhaps it run at your side without a crash ...
Same directory.
Postby eyekeelyou2 » Wed 24. Dec 2014, 19:27
I am having the same problem with SimforceGT.
Error: Zugriffsverletzung bei Adresse 005FB428 in Modul 'SimForceGT.exe'. Lesen von Adresse 000001E0.
(Access violation at address 005FB428 in module 'SimForceGT.exe'. Read 000001E0 address.)
Everything seems to be working okay until I get to the SimforceGT.. Tried running it as administrator but still nothing. I open it and it spams multiple windows with 'Rock-n-Ride Simulator' which I then have to end the process manually.
I see that some people say it happens to certain computers and they don't know why. I would like to find out how to get past this so I can start my racing setup. If anyone has new information about this problem please help me out.
Thanks.
eyekeelyou2
Postby sirnoname » Thu 25. Dec 2014, 00:13
Did you try virtual PC? Or XP Mode in Windows 7?
Postby nguyen2006 » Thu 1. Jan 2015, 04:42
sirnoname wrote:Did you try virtual PC? Or XP Mode in Windows 7?
I don't try virtual yet, but I checked the tick box "Run this program in compatibility mode for:" and chose Windows XP SP3. It also didn't work :( anything else, please?
nguyen2006
Return to X-Sim Q&A/FAQs
