SimforceGT-Simulation not working  Topic is solved solved with post #17186
Re: SimforceGT-Simulation not working
Postby lizwqd » Sat 23. Jun 2018, 08:31
I also had this devastating problem, wondering if anyone had a solution,Tank you very much :cry:
lizwqd
Postby sirnoname » Sun 24. Jun 2018, 02:56
You may use a virtual machine. This simulator has problems with some video drivers.
Postby djchamikara » Sun 10. May 2020, 20:20
If you are getting an error "zugriffsverletzung bei adresse 005fb428 in Modul 'SimforceGT.exe'. Lesen von Adresse 000001E0", when you are trying to open "SimforceGT-Simulation" tool, This is the solution.
You should set the "Regional Format" to "English (Germany)". Then it worked.
1. Type "region settings" in start menu.
2. Then open "Region settings". It will open a new window.
3. There is a dropdown list under "Regional Format" topic.
4. From the dropdown list, select "English (Germany)"
5. That's all.
This worked for me (my operating system is Windows 10).
djchamikara
Return to X-Sim Q&A/FAQs
