SimforceGT-Simulation not working  Topic is solved solved with post #17186
Re: SimforceGT-Simulation not working
Postby anjuy87 » Fri 14. Aug 2015, 02:35
Hello , I'm a beginner .. and I also experienced it now , how to fix it .
anjuy87
Postby gepsi » Wed 26. Aug 2015, 02:25
anjuy87 wrote:Hello , I'm a beginner .. and I also experienced it now , how to fix it .
I have the same problem...
gepsi
Re: SimforceGT-Simulation not working  Topic is solved
Postby sirnoname » Wed 26. Aug 2015, 07:33
We did not find the problem. It only do not run on some computers, maybe the language of the computer, maybe some other problem.
So this will not be fixed, you may start the extractor in a virtual machine with network.
Postby GeorgeNidri » Wed 24. Feb 2016, 16:18
I have the same problem...ran it in compatibility mode and that didn't fix it
GeorgeNidri
Postby ffbecker » Sat 12. Mar 2016, 06:35
Same thing happening here in both my computers. Isn't there a workaround yet? That is fustrating.. :(
As far as I have understood the SimforceGT is not mandatory, right? It is just to let me see what is/would be happening on the assembly. Would you please confirm that?
Thank you all for your support. :)
| processor Intel i7 920 @3.60Ghz | mdb ASUS Rampage II Extr. | memory OCZ Plat. 1600Mhz 6GB |
| SSD Samsung 840 Pro 256GB | powersupply Corsair 750W TX | vga EVGA GTX 970 FTW+ |
| monitor DELL 2209WA 22" | controller Logitech G27 | OS Win10x64 Pro |
ffbecker
Postby sirnoname » Sat 12. Mar 2016, 09:13
YOu can use the other simulator simulation in the same folder or use a virtual PC. X-Sim runs over network.
It is only needed for training tutorial.
It should be graphic card problem with OpenGL. Is it possible that you plug in a AMD card for a test in same system?
Postby ffbecker » Sat 12. Mar 2016, 18:04
sirnoname wrote:YOu can use the other simulator simulation in the same folder or use a virtual PC. X-Sim runs over network.
Unfortunately not. Both my computers runs on nVidia cards and there is no ATI card around that I can borrow.
ffbecker
Postby sirnoname » Sat 12. Mar 2016, 19:59
You need another opengl driver. The virtual machine has another. You can try XP mode in Win7 which comes with OS or VMWARE 12 player.
Postby gsrefurb » Thu 21. Apr 2016, 16:38
I am having the same error too, any fix for this?
gsrefurb
Postby sirnoname » Thu 21. Apr 2016, 20:46
Read the post!
Return to X-Sim Q&A/FAQs
