Arduino uno+Arduino relay shield 2.0 not work
Postby cabrio » Tue 25. Nov 2014, 16:43
Hello sorry i am new user , help! (Sorry for the English ) I have Arduino Uno + Arduino relay shield 2.0 + 2 DOF 12c , do not work with this code for Motomonstr
viewtopic.php?t=943 codes hear
Here on the site is written - is possible, but I have 2 motors spinning as they want , what's wrong? :(
Can you help me? with codes
Arduino code for dynamic playseat 2DOF
Created 24 May 2011 by Jim Lindblom SparkFun Electronics https://www.sparkfun.com/products/10182 "Example Code"
Created 24 Apr 2012 by Jean David SEDRUE Version betatest26 - 24042012 http://www.gamoover.net/Forums/index.php?topic=25907
Updated 20 May 2013 by RacingMat in english http://www.x-sim.de/forum/posting.php?m ... 943&p=8481 in french : http://www.gamoover.net/Forums/index.php?topic=27617
Updated 30 April 2014 by RacingMat (bug for value below 16 corrected)
#define BRAKEVCC 0
#define RV 2 //beware it's depending on your hardware wiring
#define FW 1 //beware it's depending on your hardware wiring
#define STOP 0
#define BRAKEGND 3
#define pwmMax 255 // or less, if you want to lower the maximum motor's speed
const int potMini=208;
const int potMaxi=815;
#define motLeft 0
#define motRight 1
#define potL A5
#define potR A4
// DECLARATIONS
/* VNH2SP30 pin definitions*/
int inApin[2] = {
7, 4}; // INA: Clockwise input
int inBpin[2] = {
8, 9}; // INB: Counter-clockwise input
int pwmpin[2] = {
5, 6}; // PWM input
int cspin[2] = {
2, 3}; // CS: Current sense ANALOG input
int enpin[2] = {
0, 1}; // EN: Status of switches output (Analog pin)
int statpin = 13; //not explained by Sparkfun
/* init position value*/
// INITIALIZATION
void setup()
// serial initialization
Serial.begin(115200);
digitalWrite(statpin, LOW);
for (int i=0; i<2; i++)
pinMode(inApin[i], OUTPUT);
pinMode(inBpin[i], OUTPUT);
pinMode(pwmpin[i], OUTPUT);
digitalWrite(inApin[i], LOW);
digitalWrite(inBpin[i], LOW);
void loop()
int sensorL,sensorR;
readSerialData(); // DataValueR & L contain the last order received (if there is no newer received, the last is kept)
sensorR = analogRead(potR); // range 0-1024
sensorL = analogRead(potL); // range 0-1024
void readSerialData()
byte Data[3]={
'0','0','0' };
if (Serial.available()>2){
//parse the buffer : test if the byte is the first of the order "R"
Data[0]=Serial.read();
if (Data[0]=='L'){
Data[1]=Serial.read();
Data[2]=Serial.read();
// call the function that converts the hexa in decimal and that maps the range
DataValueR=NormalizeData(Data);
if (Data[0]=='R'){
// call the function that converts the hexa in decimal and maps the range
DataValueL=NormalizeData(Data);
if (Serial.available()>16) Serial.flush();
//could be a parameter read from a pot on an analogic pin
int gap;
int pwm;
int brakingDistance=30;
gap=abs(targetPos-actualPos);
if (gap<= Tol) {
else {
pwm=195;
if (gap>50) pwm=215;
if (gap>75) pwm=235;
if (gap>100) pwm=255;
pwm=map(pwm, 0, 255, 0, pwmMax); //adjust the value according to pwmMax for mechanical debugging purpose !
// go forward (up)
// go reverse (down)
void motorOff(int motor){ //Brake Ground : free wheel actually
digitalWrite(inApin[motor], LOW);
digitalWrite(inBpin[motor], LOW);
analogWrite(pwmpin[motor], 0);
void motorOffBraked(int motor){ // "brake VCC" : short-circuit inducing electromagnetic brake
digitalWrite(inApin[motor], HIGH);
digitalWrite(inBpin[motor], HIGH);
void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
if (motor <= 1)
if (direct <=4)
// Set inA[motor]
if (direct <=1)
else
// Set inB[motor]
if ((direct==0)||(direct==2))
else
analogWrite(pwmpin[motor], pwm);
void motorDrive(uint8_t motor, uint8_t direct, uint8_t pwm)
// more readable function than Jim's (for educational purpose)
// but 50 octets heavier -> unused
if (motor <= 1 && direct <=4)
switch (direct) {
break;
break;
break;
break;
// testPot
void testPot(){
Serial.print(analogRead(A4));
Serial.print(";");
Serial.println(analogRead(A5));
delay(250);
void testpulse(){
int pw=120;
while (true){
motorGo(motLeft, FW, pw);
delay(250);
motorOff(motLeft);
delay(250);
motorGo(motLeft, RV, pw);
delay(250);
motorOff(motLeft);
delay(500);
motorGo(motRight, FW, pw);
delay(250);
motorOff(motRight);
delay(250);
motorGo(motRight, RV, pw);
delay(250);
motorOff(motRight);
Serial.println("testpulse pwm:80");
delay(500);
// Function: convert Hex to Dec
int NormalizeData(byte x[3])
int result;
if ((x[2]==13) || (x[2]=='R') || (x[2]=='L')) //only a LSB and Carrier Return or 'L' or 'R' in case of value below 16 (ie one CHAR and not 2)
x[2]=x[1]; //move MSB to LSB
x[1]='0'; //clear MSB
for (int i=1; i<3; i++)
if (x[i]>47 && x[i]<58 ){//for x0 to x9
x[i]=x[i]-48;
if (x[i]>64 && x[i]<71 ){//for xA to xF
x[i]=(x[i]-65)+10;
// map the range from Xsim (0 <-> 255) to the mechanically authorized range (potMini <-> potMaxi)
result=map((x[1]*16+x[2]),0,255,potMini,potMaxi);
return result;
cabrio
Re: Arduino uno+Arduino relay shield 2.0 not work
Postby RacingMat » Thu 4. Dec 2014, 22:07
this code drives motors with PWM. It allows to vary the speed of the motor (let's say 0 to 255): it requires PWM board (like motomonster)
you want to use relays which work on/off (0 or 1) that why it doesn't work
