by Marc1911 » Tue 12. Aug 2014, 21:01
Hi there,
When using worm gear motors in a 6DOF racing simulator what would be the minimum en maximum RPM on the shaft?
Marc1911
- Has thanked: 0 time
- Been thanked: 1 time
by Marc1911 » Tue 12. Aug 2014, 21:43
Duh...found the answer on Thanos's blog ->
link says: A good RPM output from the gearheads should be in the range of 14-30 RPM) So solved! Thank you Thanos
Marc1911
