by johnnyfive » Mon 28. Oct 2013, 23:37
Hi.
I've already built a test structure where the motors are mounted and now I'm figuring out the best way to physically connect the feedback pots to the geared output of these motors.
I'm in doubt about what length the arms should have for a 10cm motor arm for maximum pot precision. Any clues?
http://img220.imagevenue.com/img.php?im ... 1093lo.JPGCheers
johnnyfive
- Images: 2
- Has thanked: 0 time
- Been thanked: 0 time
by soraz » Tue 29. Oct 2013, 00:30
if you search precision, there are pots with multi-turn (like two) used with gear 2:1
or read
viewtopic.php?t=1139regards
soraz
- X-Sim Supporter
- Images: 67
- Has thanked: 3 times
- Been thanked: 7 times
by johnnyfive » Tue 29. Oct 2013, 11:21
Hi soraz.
My concern is about the length of the arms that connect the motor output to the pot, in order to achieve maximum pot resolution.
An example:
http://img220.imagevenue.com/img.php?im ... 1093lo.JPGI'll probably have to do some experiments.
Cheers
johnnyfive
- Images: 2
