Fsx motion platform
Fsx motion platform
Postby kermit » Tue 18. Jun 2013, 22:57
I'm Henk living in the Netherlands ,
And I have started a motion platform for a real Cessna 172 M cockpit section
I'm using 2 frequenty invertors , 2 ac 0,75 kw 3 ph 230 volt motors
For interface I'm using an Amc 1.6 and a board designed by vicpopo for opamp the 1-5 volt output to 0-10 volt,
I spend most of last weeks to try to drive the motor , but with no succes
I got excellent help from Thanos and have 1 of the motor turning
Greetz Henk
Following are a few pages of messages moved from My 2DOF simulator with sew eurodrive geared motors
Hi, How can I test the AMC,
I have treid to fire up the AMC ,but can`t see any data change on LCD panel , when I rotate the pot
only % can I see to change from 5% to 95% but nothing else,
Also I have connected the Amc to frequentie inverter but no reaction from the motor
regards Henk
kermit
Re: My 2DOF simulator with sew eurodrive geared motors
Postby tronicgr » Tue 18. Jun 2013, 23:06
kermit wrote:Hi, How can I test the AMC,
regards Henk
Turn on DIP SW1...
And make sure you have connected 3 potentiometers...
2 for the two motors position feedback, and 1 for the % limit in end positions of the potentiometer (to limit rotation to 180 degrees)
Postby kermit » Wed 19. Jun 2013, 23:44
Hi Thanos did that, now I have
Y127h3 X127 0
Y7 X8 V11 JR 5%
when starting profiler the AMC starts up and down showing
22 pwm v1.1 h joyr 8 bit 2dof adc fb
and apart from a flashing red led
can`t see any changes when turning the axes pots, only the % pod
im the input set up I have an joy stick asigned and see the sender y and x numbers change
greetz Henk
kermit
Postby tronicgr » Thu 20. Jun 2013, 14:46
Hi Henk,
I think you loaded wrong firmware on the AMC1.6 you have. The 22 number indicates that the firmware you used is for 22.1184Mhz crystal.
I assume you are using 18.432Mhz crystal right? Then load the correct firmware using the "fw11h18.bat" !!
Postby kermit » Thu 20. Jun 2013, 16:10
Hi Thanos , will check when I`m at home from work ,
thanks Henk
kermit
Postby kermit » Thu 20. Jun 2013, 21:04
Hi just checked
Its 22 mhz crystal firmware is oke
Greetz
kermit
Postby tronicgr » Thu 20. Jun 2013, 21:30
Some Atmega644 chips cannot run properly in 22.1184Mhz crystal. Even myself had that problem with certain batches of these chips. I think you should try installing a 18.432Mhz crystal instead and the corresponding firmware for that speed.
Postby kermit » Fri 21. Jun 2013, 12:27
Thanks for your support,
I will purchase the crystal tomorrow, and download the proper driver,
How is de Amc 1.6 called in x-sim program just AMC?
greetz Henk
kermit
Postby kermit » Sun 23. Jun 2013, 15:09
Hi Thanos ,
put in the 18 mhz crystal,and have used all afternoon to ajust the profiler but still o changing value s.
at start up
18 PMW v1.1h JoyR
8 bit 2 dof ADC FB
then AB__255__y__X
then
Y128 255 X128 255
Y7 X8 V11 JR 5%
And now I have a pop up that says at connection
Parser error check the uso parse strings
check used axis numbers and count
have axis Y a02 value 1x1+0
X a01 VALUE 1x1 +0
8 BIT BINARY OUT
Comport speed 115200 8 onestop
data pack with axisinfo AB~~255~~a01~~a02
At interface settings only input from usb yoke and
no outputs found on interfaces
Where can I check if the AMC 1.6 is working correctly and shows output values
I dont know what to do or start anymore ,
Have put a lot of cash and effort in to it but its still not working.
kermit
Postby jsmith2307 » Sun 23. Jun 2013, 15:24
Greetings :D ,
Hang in there, building these things takes a lot of TIME and EFFORT, Good things come to those that will put in a little time and effort on the project.... Be patient!
jsmith2307
jsmith2307
Images: 8
Has thanked: 12 times
