2DOF separated axis outputs
Re: 2DOF separated axis outputs
Postby motiondave » Wed 6. Feb 2013, 14:35
Tyrion wrote:They are 24V(for trucks and buses), I think they should be fast enough also. But I'm not sure if they can move each one axis seperately, since they must move whole weight of the moving construction + person per axis.
What about using 4 standard car(eg. vw golf) 12V wipers, because I saw that wiper motor simulators are noticeably slower than actuator(SCN5) ones.
So you suggest pololu JRK , amc1.6 + h-bridge or New Arduino + h-bridge project?
I have attached screenshot from my (quick sketch)model in Catia, but I think there could be too much stress on motors or even frame if I cramp motors under the seat like that without much needed leverage.
What do you think? Maybe I should use 4 motors, each on opposite sides of one axis, to releave the stress a little?
Thank you for your answers, since I really must know that before I start buying materials.
consider 12v boat winch motors if you want lift on a frame.
With JRKS, they will work fine.
Postby Tyrion » Wed 6. Feb 2013, 17:01
I was thinking more about around 150W each, which more or less equals truck wiper motor. The only thing I dont know yet if I'm going with two or four.
Is it much more hassle and trouble if you go with four motors?
Thanx!
Tyrion
Postby motiondave » Wed 6. Feb 2013, 22:32
Tyrion wrote:I was thinking more about around 150W each, which more or less equals truck wiper motor. The only thing I dont know yet if I'm going with two or four.
Thanx!
No hassle going with 4 motors , just a matter of profile writing to suit each motor ,and more control boards.
The winch motors are 250 watts each and will lift 250 kg each , easy.
Postby Tyrion » Thu 7. Feb 2013, 11:53
Could you maybe link me to winch motor your recommend. I was calling around for truck / bus wipers, but prices vary from 100 EUR (used) to 860 EUR (new bus wiper motor). So it's kinda of tough decision what to buy.
Probably if I go with 4 wipers, standard car motor should also do?
I'm pretty shure I will go in this kind of direction (http://www.youtube.com/watch?feature=pl ... jiLxx_bkrw). But does it mean I have to reprogram every .dll / game setup code to work like simulator in video or would default game profiles / setups in xsim work?
Thanx!
Tyrion
Postby motiondave » Thu 7. Feb 2013, 13:45
I only have Australian links
12v winch motor
http://www.supercheapauto.com.au/online ... 0921#Cross
12v big worm gear motor
http://www.motiondynamics.com.au/worm-d ... -180w.html
id be very surprised if a car wiper could do , even 4 of them, consider bigger motors.
that ferns sim has an airbag under it with the wipers
he did a rebuild of the frame with 24v motors without an airbag. I reckon 12v motors would do just as well.
Postby yokoyoko » Mon 11. Feb 2013, 21:44
I really like your assembly design! Where do you gt the "seat catpart" from?
Perhaps this documents can help you to calculate your problem.
Postby Tyrion » Wed 13. Feb 2013, 13:25
Thank you a lot motiondave. This design you sent me (in pictures) is really what I designed in Catia before I had any clue to start, but with four motors.
And yes you have that right car wipers couldn't do job properly I'm now going through catalogs for 24v industrial solution, I just need to find reductor that would fit them.
Great job man! Dave if you find yourself in Slovenia contact me, I owe you a beer:) Could you just please give me link to where you got pictures of the simulator in pictures you posted above. Thanx!
Thank you too yokoyoko for the chart!
I can start ordering parts *
GREAT SUPPORT GUYS AND XSIM FORUM!
Tyrion
Postby motiondave » Wed 13. Feb 2013, 13:35
I cannot find the link, I saved the photos a while ago.
As for Slovenia, a mate of mine from there is in town (Sydney), if he goes back there, he can have my beer.
Postby Tyrion » Wed 13. Feb 2013, 14:15
Shure, especially if he's also into simulator hobby, here's my mail tyrionulthuan@gmail.com:)
Is that fern's new simulator in pictures? I mean has anyone tested that design and can confirm it works.
Thanx!
Tyrion
Postby motiondave » Sun 3. Mar 2013, 08:11
Tyrion wrote:Shure, especially if he's also into simulator hobby, here's my mail tyrionulthuan@gmail.com:)
Thanx!
I dont know if its tested, although I did see a video somewhere of 180kg on it and moved with ease, mind you, he had 2 rear hatch gas struts to help hold the load. Under 120kg, it seemed to do fine without them.
I am tempted to build a design like this myself, but with the other projects on the list, it will be a llllllloooooooooooooonnnngggggggggggg time before I get to this, maybe 6-7 months at least.
