Arduino UNO/Duemilanove 2dof firmware
Postby prilad » Thu 10. Jan 2013, 07:33
Hi, Guys.
I (with my friends) has created the port of alt. 2dof firmware to Arduino platform.
It must to work at all Arduino with atmega328p - UNO, Duemilanove, ( Nano not confirmed ).
WARNING !!! There are some communication errors for Arduino UNO with USB interface on ATmega8u2. I will try to resolve this problem
resolved in new firmwares
x-sim_arduino_uno_by_Ale.rar
New Arduino UNO/Duemilanove HEX files with baud rates 9600, 19200, 28800, 38400 and 57600
(7.87 KiB) Downloaded 3249 times
Here you can found soft for uploading HEX files to Arduino:
http://xloader.russemotto.com/
IMPORTANT: after flashing Arduino UNO you must unplug it from PC and then plug in again.
This port contains all features described in this thread ...
http://www.x-sim.de/forum/viewtopic.php?f=39&t=237
... with three changes:
- COM-port Baud now is 57600.
- LCD display is not supported
- Terminal is not supported (for parameters setting use xSimCTRL software)
Connecting diagram
Here is the video with simple work demonstration:
PS: This is a project of small group of authors and testers from:
http://mal4x.ru/viewforum.php?f=6
Posted 12/01/2013
One more video - test with wiper motor.
UPDATE 24.01.2013
Have a good news. I found Sparkfun Opto-isolator Breakout.
https://www.sparkfun.com/products/9118
Two channel opto-isolator
Best regards,
Ale.
prilad
Been thanked: 37 times
Re: Arduino UNO 2dof firmware
Postby vicpopo » Thu 10. Jan 2013, 10:13
Hi Ale,
Could you explain the point for that you named '' galvanic isolation''
It's a component ?
Thanos developed a opto isolator board , it's the same princip with same components?
Regards
Postby prilad » Thu 10. Jan 2013, 10:42
vicpopo wrote:Could you explain the point for that you named '' galvanic isolation''
It's a component ?
Regards
Yes. This is a board with galvanic isolations ( http://en.wikipedia.org/wiki/Galvanic_isolation ) for each control lines. It may be based on opto-isolators as 6N137 (and you can use Thanos opto isolators board). And it may be based on "transformer" isolators, like ADuM1400 (http://www.platan.ru/pdf/datasheets/analogdevices/ADuM1400_1401_1402.pdf)
prilad
Postby prodigy » Thu 10. Jan 2013, 11:29
BobBuilt wrote:Link for dual h bridge i would love to use : https://www.sparkfun.com/products/10182
I've read some comments on this page and someone put this link:
http://dx.com/p/monster-moto-shield-for ... red-161274
It the same driver but a lot cheaper. Whats the catch?
Postby prilad » Thu 10. Jan 2013, 12:04
Hi, BobBuilt.
BobBuilt wrote:so that i may change the pin out to suit this shield, plus having a shield that just clips on over the ard will make it alot easier for new commers to play with plus the shield is already isolated and protected, no boards inbetween.
I can to create the new version, pin-to-pin compatible to Monster Moto Shield. But you must to know that PWM1 and PWM2 on pins used by this Shield has only 8-bit resolution (instead the 10-bit on pins in current firmware). And why do you say, what this shield is "isolated" ? It's not true (as I understand from schematics).
Regards,
Ale
prilad
Postby prilad » Thu 10. Jan 2013, 14:38
Hi, BobBuilt
in first you wrote:
BobBuilt wrote:plus the shield is already isolated and protected
and in second
BobBuilt wrote:The motor driver is protected internally same as the jrk to stop any power feedback or relating issues. As advised by Pololu who use the driver extensivly.
And I say, that this board has not any isolation, only protection. But this is not the same things. The POWER GROUND on this board connected to USB GROUND. I do not like this situation.
BobBuilt wrote:Didnt realize the diff in pwm pin outs, so even if hook this up with patching wires it wont work.
Please advise I can do a test.
Now connection diagram for my firmware used another Arduino pins. And you should make RIGHT connection to your Monster Shield by wire. And then you can test it.
BobBuilt wrote:Im eager been playing with a uno for a while now, just got lost in pid control. And suppose it wont be good to derate your firmware so we can use a bought shield.
By using Arduino IDE and sketches difficult to build a high performance "real time" firmware for x-sim. (IMHO) I wrote programm on C and assembler. It is not "arduino scetch"
prilad
Postby vicpopo » Thu 10. Jan 2013, 19:49
It's a component ?
Regards
Thanks Ale,
I appreciate so much all your efforts to explain simply and with a lot of pedagogy all we ask you!!
Best Regards
Gilles
Postby tronicgr » Thu 10. Jan 2013, 20:45
Optoisolation is good to have but some times could be expensive...
http://www.digikey.com/product-detail/en/ADUM1400CRW/ADUM1400CRW-ND/612551, price $8.30, but SMD
Or these http://www.digikey.com/product-detail/en/AD260AND-4/AD260AND-4-ND/617060, price $61.60, PDIP package.
Either way these are not even in stock!!!! :shock:
Postby motiondave » Fri 11. Jan 2013, 00:59
tronicgr wrote:Optoisolation is good to have but some times could be expensive...
so we wait till they are in stock then
Postby tronicgr » Fri 11. Jan 2013, 05:28
Whatever :roll:
