Postby speedy » Mon 22. Oct 2012, 01:17
Hi Mr. Prilad :
Thanks again for this fantastic program xSimCTRL ... and for your sharp vision guidance .
1- tried to change the Kp as you mentioned while Motor is on ... I was using 40/20 for Kp/hi , Kp/lo ... I used many values while in motion ... and the best results for me was 100/50 ... very fast and accurate response that made no remaining error even with No dead zone minD=0 ... also used minPWM=200 ... to give an extra PWM pulses enough to create a sufficient voltage [actually I didn't measure it yet ] in the 0-10v driving circuit to make the VFD move the motor enough to the last remaining nano position . :lol:
2- Also I zoomed the graph of motor 1 and noticed that the blue tiny line of the feedback pot position had ripples and noise onto it [ this is not from the AC motor ]... even the line of Motor 2 with the second extra FB pot has noise ... so I used a 100n capacitor to ground that noise as low pass filter [connected to DATA and GND ] ... the feed back line is now perfectly straight .
3- by that point I remembered I had a pouncing motor and noise ... also on the VFD direction and analog control lines [ that's why I use opt-isolator circuit now ] checked them now and non is found ... reviewed the settings for the VFD and found that I made a voltage step up limit 1.5V before VFD starts the motor ... returned it back to 0v with very good motor stability now [ retested with step 1 ].
Now for the accuracy of moving the motor on the xSimCTRL is beyond imagination ... for now I really need to sleep ... I posted this as preparation for the next Goal to be recorded on video tomorrow in the sunlight ... that's the best the mobile camera can do ... Sorry and promise to stop spending money on simulator and save to by a good one . :D
Regards
spe ;) edy
speedy
Has thanked: 14 times
Postby mario318i » Mon 26. Nov 2012, 23:10
Hy guys!
Sorry for the stupid question! :oops:
Is it possible to use the ATmega8535 on the AMC 1.6. Because i can not find the 644 at the Conrad-Store in Austria and i have a 8535 lying around. :roll:
If it does, can i use each firmware?
Thank you for your help!
best regards
mario318i
mario318i
Images: 23
Postby prilad » Tue 27. Nov 2012, 06:35
mario318i wrote:Is it possible to use the ATmega8535 on the AMC 1.6?
Yes (but only firmware for ATmega8535). And you must write a correct fuses for ATmega8535, they are different from ATmega644 ones.http://www.x-sim.de/forum/viewtopic.php?f=39&t=237&start=80#p2889
Regards,
Ale
prilad
Been thanked: 37 times
Postby vicpopo » Tue 27. Nov 2012, 23:10
Hi Prilad,
Nice to read you again ...
Hope I will continue trying to read something you wrote and that I can't understand ! :roll:
Best Regards
Postby prilad » Wed 28. Nov 2012, 07:01
vicpopo wrote:Hi Prilad,
Best Regards
Oh, no ... Is my English is so bad? :D . Please, all claims you must send to Google translator :D :D :D.
But seriously, very nice to see your next video with a running simulator. I hope you get pleasure from the work done. Congratulations :!:
Regards,
Ale
prilad
Postby vicpopo » Wed 28. Nov 2012, 07:31
Hi Ale,
I don't speak from your english I never had problem with .I was talking about the subject , sometimes if I don't have the enough knowledges it's not easy to understand and I like that !!!! :D :D :D :o
I was joking!
Thank you for your comments for the simultor , I'm really proud for the actually result.
Best Regards
Postby prilad » Fri 4. Jan 2013, 16:07
Hi, Guys.
I'm created the port of my firmware for Arduino Duemilanove platform (with atmega328p).
x-sim_arduino_by_Ale.zip
x-sim firmware for Arduino (COM-port speed = 57600)
(7.29 KiB) Downloaded 1303 times
Here is the video with work demonstration:
Schematics with pin definitions
prilad
Postby sirnoname » Fri 4. Jan 2013, 16:17
What is the difference between Arduino Duemilanove and UNO?
Postby prilad » Fri 4. Jan 2013, 16:29
sirnoname wrote:What is the difference between Arduino Duemilanove and UNO?
There is one difference - USB to RS converter chip. But it is doesn't matter.
There is you can found soft for uploading HEX files to Arduino:
http://xloader.russemotto.com/
prilad
Postby sirnoname » Fri 4. Jan 2013, 17:26
Ok, I also think there is no difference!
Unfortunatelly my H-Bridges are at yokoyoko and I cannot test it :(
I think this is a great project and you should open a new thread in this subforum with a title like "Arduino PID firmware". This post are shown in the project gallery in the interface subsection and are interresting for the newcomers. You should also talk there about the the UNO because it is more known.
Do you have a PID count/second for me?
