Wiper Motor Modification for fitting the feedback pots directly to the motor output shaft.
m IMG_5817web.jpg (191.53 KiB) Viewed 63690 times
Output gear removed fro motor and held in lathe
n IMG_5821web.jpg (251.08 KiB) Viewed 63690 times
Turn down the thickness of the bolt head so that it can be "melted' into the plastic gear.( heat bolt head with a small butane torch)
Hold the bolt in the the lathe tailstock chuck to produce a perfect alignment to the gear shaft.
o IMG_5823web.jpg (152.53 KiB) Viewed 63690 times
push the hot bolt head into the gear with the tailstock chuck
p IMG_5826web.jpg (207.19 KiB) Viewed 63690 times
Turn the face flush under the bolt head to restore the "bearing" face
q IMG_5827web.jpg (212.64 KiB) Viewed 63690 times
Drill a hole in the motor cover plate using the lathe.
The reassemble the motor so that the bolt protrudes through the motor cover plate.
r IMG_5829web.jpg (213.59 KiB) Viewed 63690 times
Make a mounting bracket to hold the feedback pot in allignment with the motor shaft
