Assetto Corsa plugin plus
Postby caiubbo84 » Mon 27. Jan 2014, 02:39
update 31 august 2014
Last version of plugin, now i compute the real traction loss effect! :D
19/12/14 New plugin under work....
Best regards
Valentino
caiubbo84
Images: 15
Re: Assetto Corsa plugin plus
Postby sirnoname » Mon 27. Jan 2014, 16:38
Fine, can you add (for test) at position buffer 0-4 the wheel slip values for yokoyoko?
Postby caiubbo84 » Mon 27. Jan 2014, 16:58
sirnoname wrote:Fine, can you add (for test) at position buffer 0-4 the wheel slip values for yokoyoko?
Yes, of course! I know for what utility, but i understud that it is the angle between linear velocity and angular velocity when the wheel is lost some traction .. So the value of back angle can be used for traction lost but if it is what i meen we need to moltiplicate it with lateral force to have an negative of positive sign, the slip angle for for the anterior wheel is good for abs vibration brake pedal :D
Hope to have time to implement this today
caiubbo84
Images: 15
Postby yokoyoko » Mon 27. Jan 2014, 17:49
we should pm ;)
Do you own a bass shaker?
Postby Racerr87 » Thu 30. Jan 2014, 12:12
It doesn't seem to work, can't connect to converter. It start momentarily at start up but then disconnects instantly.
Or am i missing something?
yokoyoko wrote:Hi,
we should pm ;)
Ive made my own, but have no idea how te make a good profile :oops: .
I hope that some can at more output channels to the bass shaker plugin :ugeek: .
Racerr87
Images: 7
Been thanked: 5 times
Postby caiubbo84 » Thu 30. Jan 2014, 12:40
Racerr87 wrote:It doesn't seem to work, can't connect to converter. It start momentarily at start up but then disconnects instantly.
yokoyoko wrote:Hi,
we should pm ;)
Hi Recerr87,
have you deleted the old plugin and selected the new one in the extractor? And in the new profile have you configurated correct the output? You can start from a other game profile and adapt it step by step, add one effect find the Max value ( for longitudinal , lateral and vertical it is around 28000 if I remember) ;-)
caiubbo84
Images: 15
Postby Racerr87 » Sat 1. Feb 2014, 16:28
yokoyoko wrote:Hi,
we should pm ;)
Hi Recerr87,
I got the plugin to work 8-) after adding the game manually..
I can get some motion in shaker, but seems to get only the hard/lang bump i.e. low freq, but i dont feel the curbs any idea how to set them?
Racerr87
Images: 7
Postby caiubbo84 » Sat 1. Feb 2014, 19:17
Try with vertical force ;-) in the next version I think to include tire slip angle and suspension travel :-)
caiubbo84
Images: 15
Postby caiubbo84 » Mon 3. Feb 2014, 02:14
updated the plugin in the first post! ;)
caiubbo84
Images: 15
Postby caiubbo84 » Tue 18. Mar 2014, 01:22
updated!! ;)
caiubbo84
Images: 15
