Re: Assetto Corsa
Postby yokoyoko » Sat 9. Nov 2013, 15:56
we are working on this. some patience please. ;)
Re: Assetto Corsa
Postby vicpopo » Sat 9. Nov 2013, 18:04
Hi Yokoyoko,
I watched your video with assetto corsa , your simulator is realy fantastic and seems to be very very realistic. ;)
Congratulations !!
I know also that your xsim profile is awesome . ;)
Re: Assetto Corsa
Postby Wanegain » Sat 9. Nov 2013, 22:44
yokoyoko wrote:we are working on this. some patience please. ;)
What a good news !
Wanegain
Re: Assetto Corsa
Postby prodigy » Sun 10. Nov 2013, 17:25
Where lies the problem?
I've tried to add it manually, copying wizard script from pCars and edited with AssettoCorsa details, but the error when starting game says it can't initialize Steam.
Is it something that Sirnoname can fix, or do we need to wait for developers of AC to change something in output?
Re: Assetto Corsa
Postby yokoyoko » Sun 10. Nov 2013, 18:29
prodigy wrote:Where lies the problem?
we are working at this moment on it.... we will change from UDP telemerty to shared memory. Roll pitch and yaw will be available too. If it will work :P
If something is ready I will post it here - hope this evening.
Re: Assetto Corsa
Postby caiubbo84 » Sun 10. Nov 2013, 19:29
hi to all,
this is my script:
title: Assetto Corsa startup exchange
games: Assetto Corsa (steam)
search_executable: AssettoCorsa.exe
game_parameter: steam://rungameid/244210
unicode: no
plugin: AssettoCorsa.dll
this is my script but i need to add cal parameter manualy in the extractor... why this??
caiubbo84
Images: 15
Re: Assetto Corsa
Postby yokoyoko » Sun 10. Nov 2013, 21:48
thx to the big help of sirnoname the new plugin for assetto corsas early beta is ready! :D :D :D
It now uses shared memory instead of udp telemetry which is a huge improvement :!:
We will need some users to test the following:
Please download the following text document:
Assetto Corsa.txt
(356 Bytes) Downloaded 2441 times
and place it into .../programs(x86)/X-sim/Plugin/wizard_scripts
(into the wizard_scripts folder which is in the plugin folder of x-sim)
Also you will need this new plugin:
AssettoCorsa.rar
(584.56 KiB) Downloaded 2710 times
this you will have to insert into the plugin folder of x-sim - and replace it with the old one!
After you have done this start the extractor and do an autoscan with the "game wizard".
Please report if the autoscan works and you can start the game via the play game button
Option 2: (only if the prefered solution above does not work for you!)
Please disable the autodetection of x-sim - the "X" in the taskbar should be red!
Take the plugin --->
AssettoCorsa.rar
and replace it with the old one in the x-sim plugin-folder.
After start the extractor and add the game manually with the game wizard.
this should look like this:
The AssettoCorsa.exe is located in your steam directory - Steam\SteamApps\common\assettocorsa\AssettoCorsa.exe
Choose the AssettoCor plugin
Type the call parameter ---> steam://rungameid/244210
Now you could start the game with the play game button.
Have fun!
Further infos:
- Speed, gear, effect 25,26,27 - work like expected
- Roll and pitch don't :( - can't figure out atm what kunos did there... Perhaps you can help. Pitch has an negative offset. Roll seems to be related to the "dynamic" roll of the car but is not really track related?!
- Yaw (effect 29) is 360°yaw
- Yaw slip (34) is working like in Pcars f.e. - you will have to find the minimum value where the car looses traction and set this.
---> we will need to ask in the Assetto Corsa forum for some infos on roll and pitch!
Just a quick test with the new plugin:
Best regards
Re: Assetto Corsa
Postby prodigy » Sun 10. Nov 2013, 22:39
Thanks both of you!
Right now I use only long and lat, and it's working good.
I'll try to play with pitch tomorrow to see what's going on..
Re: Assetto Corsa
Postby yokoyoko » Sun 10. Nov 2013, 23:12
@ prodigy - did you use this first described option or the second?
tzzzttzzz just 1 download until now? what's up with you guys :lol: - it's assetto corsa 8-)
Re: Assetto Corsa
Postby prodigy » Mon 11. Nov 2013, 00:35
I actually used half of first option and half of second :D
I've put new wizard script and plugin but added the game manually and call parameter. I was reading your tutorial too fast, didn't noticed options, just files to download :)
Users browsing this forum: No registered users and 31 guests
