Re: Assetto Corsa
Postby Wanegain » Thu 18. Sep 2014, 00:36
With the latest plug-in I noticed that the value of current gear has +1 with the game.
Thank you for the huge work!
Wanegain
Re: Assetto Corsa
Postby Wanegain » Wed 24. Sep 2014, 10:01
No one else has noticed that gears were wrong :? ?
Wanegain
Re: Assetto Corsa
Postby caiubbo84 » Wed 24. Sep 2014, 10:59
yes i know that gears on kunos are mapped different: 0 is R, 1 is N, 2 is first, etc... i don't used never gears on display with xsim, but i use an sli-pro, (gears in plugin is used for gear-rumble.
i'll correct it in the next update ;)
caiubbo84
Images: 15
Re: Assetto Corsa
Postby extremeX » Fri 17. Oct 2014, 19:56
Does anybody have a decent 3DOF profile for Assetto Corsa for SCN5 simulator? I tried searching the online profiles, but there are too much of them and most of them aren't even usable...
extremeX
Re: Assetto Corsa
Postby Fahim » Sun 19. Oct 2014, 18:26
Bloody hell. Anyone else fed up with Assetto Corsa and it's updates! So many and it screws everything up.
I don't use the sim for a while and I come back and it does not work.
The I use the new plugin and it works! But the profile is all MISS-MATCH.
Do I have to make a new profile everytime the plugin changes?
Fahim
Re: Assetto Corsa
Postby vittobrambi » Sun 30. Nov 2014, 13:54
Hello,
I recently bought Assetto corsa on Steam.
I updated my PC for this game...final goal to get it work with oculus rift DK2 and my 3 dof rig (currently reduced to 2 for space problems).
Check out my rig :)
[YouTube]https://www.youtube.com/watch?v=MGFHFq1Swpw&list=UUMzFwyEZ282-hHJOkqVjYSQ[/YouTube]
I am not able to get changing values on math in converter. Same for Rfactor 2 demo.
Only I can get changing values with slider test panel.
I tried to follow all steps (auto and manual) found in this thread, but nothing... :( :(
I have windows 8.1
Please help
Vitto
vittobrambi
Re: Assetto Corsa
Postby sirnoname » Sun 30. Nov 2014, 19:04
Explain your steps, perhaps something is missing like to enable the output in the game.
Re: Assetto Corsa
Postby vittobrambi » Sun 30. Nov 2014, 19:23
How do I enable the output in the game?
vittobrambi
Re: Assetto Corsa
Postby vittobrambi » Sun 30. Nov 2014, 19:33
Talking about assetto corsa, I have the latest version (i Guess V1.0.0)
I followed you tips: regedit and delete all x-sim entries
Then copied dll and txt files.
Then deleted the entry in extractor and searched again. run, but no game found.
Rfactor2 instead the game is found but no data is sent to the converter. Maybe the Demo is not working?
vittobrambi
Re: Assetto Corsa
Postby vittobrambi » Sun 30. Nov 2014, 21:09
Little progress.....
The problem is the blue icon on the bottom right of the extractor. After the game starts, it turns again blue and does not remain grey as it should.
I try and try again calling new instances of the game and, in the meantime the icon is grey, the converter does work!!!
But even when it works, I have only yaw, roll and pitch, but I do not have longitudinal and lateral force (the one I need...)
Please help... :
Vitto
vittobrambi
