Need help setting up buttkicker
Postby michaelcleo » Wed 20. Mar 2013, 17:03
I'm Mike and live in the Uk.
Gear is in my sig
I'm looking to use xsim for a buttkicker lfe on the lfe channel on its wn card, i see that the software has an option for crossover, i'd like to cut everything sub 10hz as the bk's bottom out at a higher volume on 10hz and less and this looks possible with X-sim.
So my normal audio comes through 1 soundcard but the xsim lfe signal comes from another soundcard with sub 10hz disabled here
Is this possible?
How would i go about setting it up for race room experience/project cars using audio or other racing games using audio?
I'm looking for audio only and not telementry ect
Sorry but i am such a noob and i'm at rock bottom, with alittle help to understand things i'll soon find my own feet but need help to get me started please.
GtOmega + T500rs + 1x BK lfe + 2x BK Advance
3770k, 8gb 2133mhz ram, sli gtx 670, 3x 128gb ssd, sabertooth z77, Onboard audio, x-fi titanium pcie
michaelcleo
Re: Need help setting up buttkicker for audio
Postby sirnoname » Wed 20. Mar 2013, 17:59
X-Sim does not filter your game audio output, it use real ingame values and generate output.
Postby michaelcleo » Wed 20. Mar 2013, 18:22
sirnoname wrote:X-Sim does not filter your game audio output, it use real ingame values and generate output.
Bummer.
Thanks for the info.
Any ideas about setting up a game like raceroom experience with a single buttkicker, been at it for ages now and i honestly dont have a clue, is there a buttkicker tutorial anywhere ?
Thanks and sorry for the questions, i'm not gettng anywhere on my own.
michaelcleo
Postby michaelcleo » Wed 20. Mar 2013, 18:48
This is how far i am.
Dont have a clue what todo here
These look ok ?
michaelcleo
Postby Racerr87 » Wed 20. Mar 2013, 19:55
Take a look here:
viewtopic.php?f=47&t=78
Maybe there is some usefull info in the PDF file.
Here's some info to create a profile.
http://www.youtube.com/watch?v=PQaKTaKEvCo
https://skydrive.live.com/?cid=ef237a07 ... j4qUkZbfnE
Racerr87
Images: 7
Been thanked: 5 times
Postby michaelcleo » Thu 21. Mar 2013, 09:29
Thanks,
Sadly i couldnt get anything to work so went and got *, abit piontless but hey it was late at night and id spent all day failing.
Still im going to have another go today, if i can i'll make a tut for buttkickers as anything i find seems to have holes in its info.
I've confirmed my setup works now with sivibe so its just a atter of test and fail.
michaelcleo
